Monitors Suggest 1080 LED MATT LCD display
Hi guys, my dear old CRT blew up last night.
need to buy a LCD now.
I'll buy it in Thane ( or mumbai)
requirements
1. MATT finish screen panel ( Very important)
2. 1080 resolution (for movies)
3. Good A.S.Service ( Samsung, dell etc)
4. 9-12 hours/day use.
5. Movies (mostly) and office use. Not much into gaming these days.
6. Feature known as Image size in samsung
also i need a monitor which will allow me to shift between 16:9 and 4:3 depending upon the resolution i select.
this is mainly for gaming, coz my sys can not run all games at full hd rewolution. i hate to play at 1024x768 streched at 16:9
I don't have any consoles, nor I'm planning to buy one.
I use my devices till they die, ie I don't upgrade coz a better one is available in market, so it should last long.
CRT was 8+ years old
Can I get an IPS panel in 12K approx?
(just a thought : 22" MATT IPS panel ?? :) )
Thnaks guys.
requirements
Well the options that you have for a matte screen monitor with a ~22" OR above display are [all are TN-panel based] --
  1. Dell ST2220L ~8500/-
  2. Samsung B2230 ~8000/- [lacks a HDMI-IN if I remember correctly]
  3. BenQ E2420HD ~11500/-
For IPS-panel monitors sub-12000/-, this is the solitary option --
AOC i225Fwe ~9500/-
Hope this helps, Cheerio!!
Here's another IPS panel within budget-Philips IPS LED monitor E-line 21.5"-9.5k-Buy Philips IPS LED monitor E-line 21.5 54.6 cm in Mumbai India
AOC i225Fwe ~9500/-
philips ips looks like nice deal, but its response time is 7ms. don't you think it's bit high?
will it be ok with occasional gaming?
how's philips A S Service
also i need a monitor which will allow me to shift between 16:9 and 4:3 depending upon the reeolution i select.
Just out of curiosity, will 14ms typical and 7ms G2G response time affect gaming ?
Anyways, thanks a lot guys for the help.
The purchase has been delayed a bit.
(Sadly my 15" Samtron 55V (10yr old) is working fine and I'm forced to use that only. She says I'll watch less movies :( )
(friendly advice to men: Never ever open a joint account :p )
See if you can find a LG IPS225V.
There is another option,Philips 227EQPH,I am not sure if its cheap and cheerful.But saw some review saying isnt that bad.
