nRiTeCh
I work late nights on my pc and keep the lights off so as to not disturb sleep of my family members. But then I have struggle through my keyboard hence suggest me a vfm USB LED Light solution.
Most of you be using it on laptops and I wanna use it on desktop.
Do I necessarily have to go for something like these ones having multiple leds Or even a normal ones will do and give enough light to clearly see the keyboard keys in pitch dark?
Dont suggest any fancy or expensive stuff, just some vfm who'll get the job done.
I'll plug it to the front panel usb and unsure whether it'll provide the required power to lit it bright enough.
If not then do these come with a long usb cable to plug into back panel?
