PC Peripherals System Config for 30K....Need Advice
bejay
Hey Guyz.....my COz wantz to get a new sys under 30K....with Gud 2.1Spkrs....pls suggest.....AMD or Intel????Heard Intel Zeon is gonna overtake AMD.....plz suggest.....n wat about dual core?????Also wanna know best VGA/Graphics Card n Monitor (Preferably LCD).....with UPS........All this under 30K.....Possible???Any Suggestions?????
Dude...u can go either for AMD64 based system or Intel core 2 duo rig...i suggest the core 2 duo...but watevr u do..plz don't go for intel pentium d....they suck big time....
With ur budget...if u go for 17' LCD...u'll have to compromise on some stuff say like a gud gfx card...it all depends on u dude...
AMD RIG:
AMD Athlon64 3200+ (S939/AM2) - 4k
Asus A8N-VM (or VM-CSM)/ASUS M2N-PV-VM (AM2) - 3.5k to 5k
Transcend 512MB*2 DDR400/DDRII 533 - 5k to 6k
Seagate 7200.10 160GB SATA - 3.2k
LG/SAMSUNG 17' CRT - 4.5k
BIG Geforce 7600GS - 6k
Logitech K/b + mouse-0.7k
Creative 2.1ch - 1.4k
Roughly comes arnd 31k i gues...it'll b a gud midrange system
for intel core 2 duo...u can go for E6300- 8.7k
Asus M2n-E - 5k
rest everything will be da same...now it's ur widh dude.!!! all da best!!
AMD RIG:
Asus M2n-E - 5k
The config looks good ..... try and squeeze in the core2duo and don't get the BIG card...try for XFX/Leadtek :)
Let me suggest an intel based c2d rig which will fit in your budget...
intel c2d e6300 @1.86ghz: 9-10k:clap: :hap2:
asus p5ld2 vm se: 4.5-5.5k
512mb ram: 2.8k
seagate 80/160gb: 2.2k/3.2k
cabinet: 1.2k
creative speakers sbs370: 1.2k
dvd writer: 2.2k (Go for the lite-on model...)
ups: 1.6k
monitor: This you have to decide. If you want a LCD in this budget, you might have to compromise on the viewing experience... Most lower range lcds have a response time of 12 ms... resulting in ghosting. Secondly, their colour reproduction cannot match that of a crt. So, if you want to go in for a crt, the basic 17" will cost you 4.7-5.2k... A flat crt ( for e.g LG Flatron ) will cost you around 6.5k..
Talking about newer technologies, my suggestion to let the hot product be introduced and simmer for a while...
A good lower range graphics card is 7300gt.. around 4.5k... Can overclock it and get good framerates...
PS:If you do stretch your budget, go for a gig of RAM.. And remember to buy two 512mb sticks instead of a single 1gb stick... Huge performance difference.. upto 15%...
Hey guyz thx for the advice....keep it pourin in.....
@Siddharth......dude 512MB RAM - 2.8k.....are u sure????Guyz hv the RAM prices come down again????
