PC Peripherals System Starts Automatically When Ups Is Turned On
DavyJones
Member
Hi guys ,
Recently i replaced my mobo ( DH67CL) b'coz of some issues. Now when i start my ups the system starts automatically. I don't know what causing it. I didn't changed anything in the bios. The only thing i changed in the system is that i replaced the mobo with a new one ( Same model ). Does anybody have any idea??. This problem only started after i changed the motherboard. pls help guys.
bottle
Caffeine Addict
Staff member
There should be a setting in the BIOS like a/c power on state with options like memory,always on, off afaik, change it to memory so that when the mobo received power it either turns on or stays off depending on what the pc state was before the power went off
CA50
#[member='DavyJones'], check BIOS setting. There must be a setting like - Restore on Power : ON / OFF / LAST STATE
Change it to OFF
jinvidia
Active Member
i dont think any option can have the effect of powering on the pc, though the board starts to recieve power as soon as the ups is swirched on.
Did you change anything in the bios ?. I hope by default the bios is not set in that way. Moreover you had the same board formerly...
DavyJones
Member
thnx for your replies guys. I didn't change anything in the bios. the current power settings in my bios are below
Intel Dynamic Power Technology
Enhanced Intel speedstep technology - Enable
Processor C states - Enable
System Power options
After Power Failure - Stay off
Wake on Lan From S4/S5 - Power on-Normal boot
Deep S4/S5 - Disable
S3 state indicator - blink
wake system from S5 - Disable
PCIe ASPM support - Disable
Flash Update sleep Delay - Disable
These are the default settings. I didn't change anything. I have no idea whether the power pins are short. It was working perfectly with the old mobo
CA50
#[member='DavyJones'], BIOS setting looks all right.
If problem persist, then reset the BIOS, and re-configure it
