TP-Link TL-WR841N range problem
S.H.A.D.E
The Paladin
Hey everybody,
I bought a TP Link TL 841N router a few months ago and everything was working fine until 3 days ago. The router signal started dipping and at places where i used to get 2-3 bars, I started getting no signal at all. I tried resetting the Router but that didn't fix anything. I'm wondering if I'll have to place it for warranty. Any input is welcome!
Thank You in advance! :)
vivek.krishnan
Veteran
Check with WiFi Analyzer if there are any other WiFi networks causing interference. Also, try relocating the router and check. Also see if you can adjust power levels.
S.H.A.D.E
The Paladin
At some spots I get 3 bars, I turn around and no signal at all! I get 3 bars while on my bed and I stand up near the bed, no signal! It's pretty weird..
prateekS
Veteran
I am using 841 atm, and face no such problems.
Get the unit rmaed, they send you a new unit. U can visit them or courier it to them, address on TP Link India website.
