adventureguy
Innovator
Hi,
my config is as below:
CPU: i5 4460
GPU: Asus strix Gtx 960 4GB
Ram: Corsair vengeance 8gb
SMPS: AntecVP500PC
Mobo: gigabyte B85M-Ds3h-A
SSD: Kingston 120gb
I have a zebronics 600va UPS and I also have inverter. The problem is whenever theres a power cut, the inverter takes a sec to turn on and in the second, the UPS is turning off thereby effectively turning off the pc. If I turn on the UPS again, it turns on and my pc works fine.
So What may be the problem here? Isn't 600va ups sufficient for my system or should I just replace the battery in UPS or got a new UPS (maybe 1KV one?)
CPU: i5 4460
SMPS: AntecVP500PC
SSD: Kingston 120gb
