saqib_khan
Contributor
Hi,
I am using a Samsung LCD monitor that comes with a native resolution of 1920 x 1080. Everything's working fine , till now, but recently my resolution changed to max 1600 x 1200. There;s no option for 1920 x 1080. The same thing happened in both my OS - Win 7 and Win 8.
I tried changing my VGA cable with my friends' and everything works great, and I can even select 1920 x 1080 resolution. I bought two VGA cables from the market, but both have the same problem, but only my friends' cable works great. Weird.
Should I buy DVI cable instead? If yes, then which one? DVI D, DVI I and all, its confusing. I think my monitor has DVI D dual link output, but my motherboard has DVI I dual link out. So now, which cable should I buy?
Would be great if someone can help me here. I am really confused.
