[font=helvetica, arial, verdana,]Hi![/font]
[font=helvetica, arial, verdana,]My homework is to make a c program for game of life. I have made my code already, the problem is when i'm running the code the compiler doesn't display any error, but my code still doesn't work well. I have to print in the screen an initial generation coming from a textfile, from that initial generation, I have to calculate the next generation using the rules of the game. After calculating the next generation I should save it from another textfile.[/font]
[font=helvetica, arial, verdana,]Rules of the game: [/font]
[font=helvetica, arial, verdana,]1. An organism will survive if it has exactly 2 or 3 neighbors.[/font]
[font=helvetica, arial, verdana,]2. An organism will die if it has less than 2 or more than 3 neighbors.[/font]
[font=helvetica, arial, verdana,]3. An organism will be born if it has exactly 3 neighbors.[/font]
[font=helvetica, arial, verdana,]I think I applied the rules of the game well, however I have no idea why my code still can not calculate the next generation.[/font]
[font=helvetica, arial, verdana,]I hope you guys could help me.. Thanks a lot!! by the way my board is a 25x25 matrix of the character 'X' and 'blank space'. 'X' corresponds to a living organism.[/font]
here is my code:
#include <stdio.h>
char initial [50][50];
char generation1 [50][50];
int counting_neighbors (int i, int j) {
int neighborscount;
neighborscount=0;
if (initial [j+1]=='X')
neighborscount ++;
if (initial [j-1]=='X')
neighborscount ++;
if (initial [i-1][j]=='X')
neighborscount ++;
if (initial [i-1][j+1]=='X')
neighborscount ++;
if (initial [i-1][j-1]=='X')
neighborscount ++;
if (initial [i+1][j]=='X')
neighborscount ++;
if (initial [i+1][j+1]=='X')
neighborscount ++;
if (initial [i+1][j-1]=='X')
neighborscount ++;
return neighborscount;
int main() {
int i, j;
int neighbors;
char filename[10], initialgen[26];
char *g;
FILE *fp1;
printf ("Enter filename of initial generation: ");
scanf ("%s", filename);
fp1=fopen(filename, "r");
i=0;
j=0;
do {
g = fgets (initialgen, 26, fp1);
for(j=0;j<26;j++){
initial [j]=g[j];
i++;
if (g!=NULL)
printf ("%s", initialgen);
while (g != NULL);
fclose (fp1);
printf ("\n");
neighbors=0;
for(i=0;i<25;i++) {
for(j=0;j<26;j++){
neighbors=counting_neighbors(i,j);
if (initial [j]=='X') {
if (neighbors==3)
generation1 [j]='X';
else
generation1 [j]=' ';
if (neighbors==2)
else
if(initial [j]==' ') {
if (neighbors==3)
else
fp1=fopen ("gen1.txt", "w");
if (fp1!=NULL) {
for(i=0;i<25;i++) {
for(j=0;j<26;j++){
fprintf (fp1, "%c", generation1 [j]);
fprintf (fp1, "\n");
fclose(fp1);
printf ("Generation1:");
for(i=0;i<25;i++) {
for(j=0;j<26;j++) {
printf ("%c", generation1 [j]);
} printf ("\n");
return 0;
}[font=helvetica, arial, verdana,] [/font]
here is my code:
#include <stdio.h>
int neighborscount;
neighborscount=0;
neighborscount ++;
neighborscount ++;
neighborscount ++;
neighborscount ++;
neighborscount ++;
neighborscount ++;
neighborscount ++;
neighborscount ++;
int main() {
int i, j;
int neighbors;
char *g;
FILE *fp1;
i=0;
j=0;
do {
for(j=0;j<26;j++){
initial [j]=g[j];
i++;
if (g!=NULL)
while (g != NULL);
fclose (fp1);
printf ("\n");
neighbors=0;
for(i=0;i<25;i++) {
for(j=0;j<26;j++){
if (neighbors==3)
else
if (neighbors==2)
else
if (neighbors==3)
else
if (fp1!=NULL) {
for(i=0;i<25;i++) {
for(j=0;j<26;j++){
fclose(fp1);
for(i=0;i<25;i++) {
for(j=0;j<26;j++) {
} printf ("\n");
return 0;
