deepakvrao
Hi Guys,
Decided to go the water cooling route. Seen these Corsair ones, but a) dont know which to pick of the two? and b) dont know if they will fit my case. Case specs attached. Any help would be really appreciated. Looking at the H115i series, but they seem to have a few variants, mostly with different pumps and different fan max rpms?
The case is the NZXT 510
Hydro Series™ H115i PRO RGB 280mm Liquid CPU Cooler
The CORSAIR Hydro Series H115i PRO all-in-one RGB liquid CPU cooler with a 280mm radiator built for low-noise cooling and bold styling with an RGB LED pump head.
www.corsair.com
Hydro Series™ H115i RGB PLATINUM 280mm Liquid CPU Cooler
The CORSAIR Hydro Series H115i RGB PLATINUM is an all-in-one liquid CPU cooler with a 280mm radiator and vivid RGB lighting that’s built for extreme CPU cooling.
www.corsair.com
