1. my acer 5740g and Sony Vaio VPC CW - CWS1S1E when connected using adhoc network we get speeds of 16 MB/s i.e 150mbps .. (using connectify software for adhoc creation) ..
2. on any other laptop combination our speeds are limited to 11mbps , why is it so ??
like my acer and some dell , or any other combination .. all wifi settings are set to maximum performance then also why is it slow speed ??
is there any setting to do ??
i read it somewhere that adhoc speeds are limited to 11mbps ?? is it so ?? even if the card is 802.11n ..
i tried connectify and virtual router for adhoc creation even windows simple adhoc ..
how to get the 150mbps speeds ?? when both cards are 802.11n supported ..
