jammy420
Hi all,
My HDTV is going to be my only display for my desktop. I do not have any other monitor. I want to keep my desktop little distant from my TV and connect it through wireless. I am running windows 8.1.
How to do it? Will Teewee or chromecast work for this purpose? or is there any other way to do it? I want to play videos, surf the net and do all normal work in desktop in windows, but the desktop will sit bit far from my TV. I have a wireless modem, which may be (if it is possible) for transmitting HDMI signals... I am looking for a HDMI receiver kind of device for my TV which can do the receiving side. Since My HDTV is going to be my only display, I am looking for a solution, that once I power on my PC and HDTV, the display should be there on the TV, otherwise, no way I can sort out the wireless display connection. May be, something like the Teewee/Chromecast App should be as a start up program in PC ? or any other solution please?
Thanks,
Partha
Thanks,
Partha
