guys am having a cm 690 wid transparent side panel.. L shaped one
and its got the stock 3 fans including the front blue led fan..
now am thinkin of addin some more bling to it..
am thinkin of goin for 2 led fans... red ones...
wud these be enuf...ill put one red one on the side panel..and one at the back as an exhaust which is very much visible from the side panel....and put the stock ones one at the bottom and other one at the top..is it a good idea?
am gettin 2 red sunbeam 45.91 cfm fans for rs 350 each..
wud this enuf to light up my cabby??
i think of ccfl as too much of a hassle..and they radiate some heat..
the temps are very good ...atm... everythings on stock..but i do plan to push my q6600(43-45 idle) upto 2.8 on stock cooler..
and the temps on my hd 4850 are also good...39..idle and 50-53..load
so what are ur suggestions....cant spend more than 600-700 bucks
