FS: Others [Giveaway] Zebronics front panel controller and 2 fans.
joy.das.jd
Feedback: 90 / 0 / 0
Noida
1 out of 5
  1. Bank Transfer
Excluded - at actuals
None
No
Upgrade
Hello everyone,
As the title says, i have the zebronics front panel controller and 2 fans for giveaway. The front can measure the temperature, you can set an alarm for certain temperatures, and set normal alarms too.
The two fans are possibly 80 mm fans. I am not sure if you can reuse the fans without the controller. One fan connects to a molex cable so possibly that can one can be run separately. The other connects to the controller via a 2 pin connector.
The molex fan is green in color and 2 pin one is a blue led fan.
Both fans will need further cleaning and the fan controller will need a battery replacement (uses a single cr2032 battery, also known as BIOS battery with most shop keepers)
Unfortunately I CANNOT test them for you. Rest assured they were working fine about 3-4 months ago (i was still using the ancient cabinet. Lol)
Hello everyone,
Ygpm
