kaneunderground
System registry problem... Amds are very famous for their drivers. Install old drivers & check .. Its not the issue with PSU for sure. Later download new drivers & check if not happening install OS & check !
Remove all driver remnants using Driver Sweeper method. Make sure Hardware properties see the GPU as a stander PnP, then install 11.4 again.ragzdiablo said:Im back to catalyst 11.1 and running on 900 mem clock..
the random freeze aint a problem now, but still my driver crashes and then comes back after 2 mins.. :S
Thanks, let me try that out..asingh said:Remove all driver remnants using Driver Sweeper method. Make sure Hardware properties see the GPU as a stander PnP, then install 11.4 again.
Done. the problem remains!asingh said:Remove all driver remnants using Driver Sweeper method. Make sure Hardware properties see the GPU as a stander PnP, then install 11.4 again.
lock your core of b50 and then try.... I am using the same config you are using. But in my case its phenom b40...ragzdiablo said:Done. the problem remains!
Drivers for PSU? What are you smoking? :no:Ameet148 said:Gigabyte and ATi are famous for their crappy drivers .
See even if uninstalling and reinstalling drivers is not solving your problem then i would advice you to clean install windows 7... Doing this may solve your problem...ragzdiablo said:Im back to catalyst 11.1 and running on 900 mem clock..
Yeah do this as Hades has suggested. Take a backup of the data and do a clean install.Hades. said:See even if uninstalling and reinstalling drivers is not solving your problem then i would advice you to clean install windows 7... Doing this may solve your problem...
toolius said:ATI power play is playing with you..
you can disable it in registry ... are you using any programs like afterburner to monitor your card ?
If so thats your problem . Dont use them and see if you crash !.. look up power play problems on google tons of stuff
cheers and kind regards!
