jith77 said:I had recently changed my mobo to gigabyte s21. None of the usb ports(front and back) detects any usb device. Any tips for troubleshooting.
The Sorcerer said:If you have the windows xp sp3, you seem to be facing the same issue like this guy:
http://www.techenclave.com/operatin...after-reinstalling-xp-128221.html#post1043224
stellarhopper said:dont 'load optimized defaults'
go to the actual setting and check if usb is enabled...esp something like mass storage function usually...
RamPagE said:Do 1 thing...
Right click MY Computer>>Manage>>Disk Management
Se if it shows up there![]()
Eazy said:Have you installed the "chipset" drivers which come on the Driver CD of the MoBo ? Actually download and install the latest version of the chipset drivers available on the MoBo makers download page.
