How to connect ps3 to LCD monitor ?
@neojjjk - So did it work for you? I am using the PS3 connected to my monitor through DVI, let me know if I can help.
@neojjjk - Before proceeding check if your monitor is HDCP compliant. If it is a simple HDMI to DVI-D cable will do the trick for video.
I think I have manually set the the resolution to 1920x1080 on my monitor despite it's native resolution being 1680x1050.
The only 2 games I have problems with are - Virtua Fighter 5 and Gran Turismo 5.
In Virtua Fighter 5 a bit of the screen goes outside the bounds.
In Gran Turismo 5 I get a letter box effect.
Neither of them are deal breakers though.
