My first foray into Water cooling
May 17, 2009
1,050
613
203
Hi Guys
i had always wanted to build a water cooled PC and was too afraid to set one up , however fast forward bit the bullet took help from a friend and was able to finish this build
The specs are as follows :
AMD Ryzen 5900x
Colorful 3090 Advanced OC
32gb Trident neo Z C16 3600 Mhz kit
ASUS ROG Dark Hero
LG 27GN950 4k 160hz Display
WD SN850 1tb NVME
Samsung 980 pro 1tb NVME
4 x 4 tb WD purple drives
Lian Li Dynamic O11 XL
Lian Li Strimer plus
Lian Li Uni 120 White kits x 3
EK Mystic fog cryo fuel concentrate
Barrow CPU and GPU Block
Barrow Distro plate
Barrow Flow and Temperature meter
Barrow PETG tubes
Barrow Wolverine fittings and D5 pump
GMMK White ice keyboard with custom cable from Kable makers ( Cable is inbound)
Glorious model D white matte
Glorious extended Mouse pad
1,050
613
203
Looks great. Where did you source the Flow+Temp meter? Also, did you paint parts of your Dark Hero white?
Thank you mate, yes i did paint the dark hero or what i call Dark hero after fair and handsome cream :D , i sourced the meters from tweakedPC, you could look them up on facebook.
Fenix
Radhey Krishan
Sep 2, 2008
1,874
1,182
252
This looks amazing. I am curious to know the total cost of the water cooling parts you paid including the shipping. Looking at the Lian Li Dynamic XL or Entho 719, I feel like having a water cooled rig myself.
May 17, 2009
1,050
613
203
awesome looks,
but but where are the before and after temps?
i fortunately never had the opportunity to use it on air , this was built directly on the custom loop
Just saw this, it's absolutely stunning. How'd you paint the heatsinks and the IO shroud?
Thank you mate , i got the paint job done by a Vinay at Gamerz nation Pune
Id say go with O11 XL , O11 is quite small if youre into WC, well my total build came close to 5L
Your build is stunning. How tough was it to do the water cooling parts ?
Thank you mate , a friend of mine did the Water cooling portion of it for me , the Tube bents , fittings and stuff , im working on redoing the entire loop again, stay tuned :) with a custom distro plate
Sorry for the late replies guys, was too occupied at work and other commitments, im going to redo the loop with some changes , i shall post an updated version very soon
Reactions: Trazer854
startekselva
4
37
18
good but use acrylic tubes dont use PETG it will clog after long time of use
check my build log
May 17, 2009
1,050
613
203
check my build log
yes thats the part of the plan im moving to Acrylic satin tubes for the frosted look, the end result would be totally different, also planning on getting a custom distro plate made
badgangstaa
20
28
67
Good to see a Beautiful Overkill PC build.
Looks Amazing.
All the Specs are top notch.
Except the RAM.
Please don't mind, But I think 4400Mhz or 4600Mhz would have been better for your high end CPU and GPU.
Also, I am a little curious about the 4 WD Purple HDDs.
I haven't seen anyone use WD purples in their PC build. And there are valid reasons for not using those purple drives to save your precious data.
Read this.
