2 670s will set you back 55-60k easily. And I would have a complete top notch setup with a 680 Custom OC or 7970 Custom OC, on complete water cooling than just 670 SLI with an average setup.
Besides, no matter which way you go, within 12 months you will have single GPUs which will be better overall packages compared to either. So 670 SLI means you will be spoilt and will need to spend 60k+ on GPUs every year or so.
Unless you can afford to spend that kind of money regularly, stick with a single card as that is far easier to upgrade, manage
