Hello Guys,
I am in lookout for a PC . As I has already decided with the monitor I need your suggestion with the CPU,mobo,cabinet,HDD,DVD/bluray drive,. The cabinet should be of good quality. If the PSU comes with cabinet its fine else I am open for a standalone PSU.Speakers should be 2.1. Below is my requirements as per the template.
Q: What is your budget?
18kThough I am open to increase the budget, my usage doesn’t need expensive PC, atleast I think so.This includes PC without monitor. For monitor I almost decided upon u2311H.I will be more than happy if the PC can be made with lesser budget. Also for speakers I have separate budget of 4K. I am sorry if I sound confusing.
NA
NA
I haven’t decided anything yet.
In future I may add a Xonar sound card.
Bangalore and Open to online purchase as well.
No
Q: What is your intended use for this PC/hardware.
Watching HD movies(This is the main purpose. The mobo should have best audio hardware. By best I mean as good as it can get within my budget)
Browsing
SAP software.
I am open to any brand.
NA
I have no idea regarding this.
NO
Windows 7 , ubuntu
NA
NA
No
Browsing
SAP software.
NA
NO
Windows 7 , ubuntu
