Okay, so I built my PC as you might have seen in my other thread. Link
My PC Components:
CPU - AMD Ryzen 5 1600
Mobo - Asus ROG strix b350f gaming - Link
RAM - 2x8GB Gskill trident z RGB 3000 MHz F4-3000C16D-16GTZR - Link
PSU - Seasonic M12ii evo 520W fully modular - Link
GFX - Zotac Geforce GTX 1060 6GB mini - Link
Case - Coolermaster Masterbox 5 RGB - Link
OS - Windows 10 pro x64 OEM
Nothing is overclocked now and nothing was ever overclocked. I built the system on 6th September 2017. All drivers are latest as of today 22/sep/2017. ASUS released a BIOS on 15th which I installed on 19th sep on the motherboard successfully. This BIOS has agesa 1.0.0.6a. UPDATE: I just noticed that ASUS has released BIOS 0902 on 20/sep/2017. Just updated my BIOS to that. This BIOS now comes with AGESA 1.0.0.6b update. It did NOT resolve my issue. My PC could only POST at maximum 2666 MHz right now.
Version 0811
2017/09/15 update 5.75 MBytes
ROG STRIX B350-F GAMING BIOS 0811
1.Improve memory stability
2.Fix secure erase locked issue on Samsung M.2 SSD
Now, my issue. Since I have bought the system, I have not been able to run the RAM above 2666 MHz. By default, the RAM curiously runs at only 2133 MHz which is what is mentioned in SPD also. I have enabled DOCP profile which populates the BIOS to let the RAM run at 2933 MHz with the mentioned Tested Latency: 16-18-18-38 and it automatically increase the voltage from 1.2 v to 1.35 v. But, my system wont POST. Then, I decreased the frequency to 2800 MHz. It kept running without issues for a few days. Day before yesterday, the system crashed on idle. Then it wont POST even at 2800 MHz. Disappointing. So, I reduced the frequency again to 2666 MHz and its running stable now. I have tested with Prime95 and left the system running for 11 hours and it does not show any errors. When it was running on 2800, it didnt show any errors and neither is it showing any errors now at 2666 MHz. And yes, I was running the test in which it stresses the RAM.
I have already checked the interwebs for the past 20 days with no results. Some people claim their kit is running at even 3200 MHz stable with ryzen setup. This RAM is not on the QVL of my motherboard which I knew before buying it. I bought this RAM because I like Gskill and because this was the only acceptable RAM available in Bangalore. None of the RAM kits mentioned in the QVL is available here.
I would really appreciate if you can help me out and if you have had experience with the similar setup.[DOUBLEPOST=1506081268][/DOUBLEPOST]UPDATE: I just noticed that ASUS has released BIOS 0902 on 20/sep/2017. Just updated my BIOS to that. This BIOS now comes with AGESA 1.0.0.6b update. It did NOT resolve my issue. My PC could only POST at maximum 2666 MHz right now.
My PC Components:
Version 0811
