Audio Sennheiser RS 175 stopped working and pads torn
renegade
Staff member
Super Mod
Dec 31, 2004
6,474
1,459
302
Pune
I had bought these in 2015 and now the base station stopped powering up one fine night. What are the options to get it repaired once the lockdown eases?
Also is there a place I can get all the pads for the headphones? The pads on the can have ripped out and the one for head support has also come off with a sticky glue underneath.
I had thought of buying another headphone for the base station but that never happened. :(
N
NotMyRealName
Have you tested if the ac power adapter is working first? These modern SoC type electronics aren't really repairable but sometimes you may be lucky and it's just a blown capacitor or something. Still a 50-50 chance of a local repair guy fixing it.
puns
Staff member
Super Mod
Mar 24, 2005
2,046
1,764
253
Mumbai
Earpads - you can try sennheiser india website or headphonezone
If I am right, 165, 175, 185 have same pads
