sagar.sdm
Please suggest options for buying a 42"/46"/47" or larger FHD LED or LED LCD TV.
Info:
I owned a LG 42LW5700 earlier. This one had amazing PQ. Almost everytime I saw a HD video on this, I use to awe. Viewing angles were great. Although 3D feature was good, never used it beyond demoing it ourselves and to the visitors.
But, 3 months in to the ownership the panel showed 8-10 dead pixels in the left half. I got the panel replaced under warranty. Checking the original panel model with the replaced one, I found out that the replaced panel was inferior. It was also apparent from the considerable decrease in PQ of the replaced panel. I fought with LG, wrote a mail to them, they agreed to my plea but could not find the original panel as its manufacturing was discontinued, after much persuasion I obtained a full refund for the TV today; after close to 6 months. Phew.
The LG personnel will be taking back the TV today, and frankly it is disheartening to let go of this TV; given how good its PQ was on its original panel. This brings me to hunt for a new TV that is at least on par with my ex-TV, if not better.
Options I'm considering based on my research so far -
1. Samsung ES5600R Series - only concern is that it's a 50Hz panel, and how good its PQ is. I am aware of panel lottery system. If I am to buy this will make sure to get one having SPVA, negotiating with the dealer. Yet to demo.
2. LG LM6410/6700 Series - 120Hz. Presuming PQ on this must be comparable with my ex-TV. Does not have a headphone jack. Yet to demo.
3. Your suggestions.
I am sure some of you would suggest Sony 46EX650, one of my relative has 40EX650, and somehow I don't seem to appreciate its PQ. His TV was bought from grey market though. I need to demo one in a Sony showroom to check if it is any better.
TIA.
Info:
- Budget INR 70,000 +/-
- 3D feature not required
- Smart TV not a necessity, if present in-built WiFi will be a plus
- At least 2 HDMI & 2 USB ports
- Decent PQ - for both SD & HD - a must; Use Videocon DTH HD as cable source via HDMI
- Audio quality not a concern - will be using F&D A520 for TV audio.
- Viewing distance ~8+ ft
- NTFS USB support & playback support to all common video/audio formats will be a plus
- True Refrest Rate of 100/120 Hz at least
- (confused here, my earlier TV had 120Hz, how much does this matter against a panel with 50/60Hz in terms of PQ? I would be happy if there in less to no blur in fast moving scenes)
- PC input (VGA) will be a plus
- Headphone jack will be a plus
- 42"/46"/47" - whichever fits my budget. PQ takes precedence to size. However, having had a 42" before it would be hard to settle for a 40" now.
- Based in Bangalore
- Will consider buying from grey only if the cost benifit is very lucrative. Although, will have to do my reasearch to find a well-known shop known for genuinity.
TIA.
