c programming text recommendation!
iml3g3nd
New Member
823
41
0
can u guys recommend me a text book for c language??
i m currently using " let us c"
the book is quite good and simple but lacks example programs!!!
which other authors book should i get ????
rapt0r
New Member
699
11
0
If you are just planning to clear ENGG exams with good marks then that book is very good . There's also one "Programming in C" by balaguruswamy . If you seriously want to dip in C then go for some foreign authors .. O'reilly publication has some really nice books .
iml3g3nd
New Member
823
41
0
can u give a specific title of the book?????
my concern is not just clearin ENGG!!
tirthankar
New Member
329
17
0
34
If you are willing to dig deep and work hard then i would recommend my favourite.. The C Programming Language by Ritchie and Kernighan.
straight from the horse's mouth.. :)
Gurpartap Singh
Active Member
656
19
31
30
gurpartap.com
E Balagurusamy
iml3g3nd
New Member
823
41
0
does the book by balagurusamy xplain every concept of programming with good xamples????
and does opting a foreign author book help???
sandy453
Active Member
Nov 21, 2006
233
12
31
+1 to that.is a little hard on beginners .But this is one book every c programmer must read .
jigarpatel
Active Member
158
1
28
36
If you really want to learn C in depth get book from denis richard only and also get it's answer book.
Rahul++
SuperUser
Aug 27, 2007
3,142
175
152
27
Pune
www.wrapcode.com
If you are just stepped in C Programming, I would recommend you to prefer Let us C and E Balagurusamy...
Foreign author books are for intermediate programmers...
Buygamingstuff
New Member
959
17
0
32
www.buygamingstuff.com
dude yashwant kanetkar's LET Us C is the Best .Ask neares Book store for LET Us C solution ,where all the exercise Question are Solved .Trust me that with Let us C only u can be little master of C .
However incase you are planning for C++ ,then balaguruswami should b your choice
Safin
Super Mod
Dec 6, 2004
3,330
105
151
All over the place!
www.snlogic.com
Somehow i have never ever liked Let Us C. Its a terrible book for newbies :lol: (Thats my opinion anyway :lol:) Kanetkar has written some 7 different books when they should all be one (Pointers in C, Graphics in C, C Demystified,,,, and many others)
Personally i would recommend this one if you are doing it just for your engineering exam. The Waite Group's C Programming Using Turbo C++ by Robert Lafore (Used, New, Out-of-Print) - Alibris (The Waite Group's C Programming Using Turbo C++ - By Robert Lafore) The best as far as newbies to the language go.
tirthankar
New Member
329
17
0
34
that would probably be denis ritchie.. :)
cool_cat
May 12, 2008
765
35
92
Cochin,India
www.getgnulinux.org
K&R .those who are very weak with Math ,try C for dummies 2nd edition.
always learn with the standards(ANSI/ISO) using gcc/g++ and some good ides like Anjuta and not with those turbo c /visual c++ etc :) My 2 rupees(not cents).
Avtar
New Member
Jan 1, 2005
430
23
0
30
www.avtaronline.com
Robert Lafore's Object Oriented Programming with C is a very good for beginners, it gets you up to a good level and has some real world examples in it.
Rubbish like Balaguruswamy just makes me want to burn it, the amount of errors in the programs is ridiculous. Let Us C by Kanetkar was pretty good, but not a good "read" as such.
Robert Lafore is the way to go, otherwise get the Schaum's Outlines of Programming with C.
If you're just beginning and if you want to be an advanced programmer, Ivor Horton's "Beginning C, from Novice to Professional" is the way to go.
iml3g3nd
New Member
823
41
0
after reading many posts !!
i have seen that many recommending "introduction to algorithm" by cormen
and also read that for hardcore theres "art of programming" by knuth !!!
i took both of these books from the library just to read it.....
the first volume of the 5 volumes by knuth !!
cormens book was handling only algorithms and the efficiency of each algorithm in real time.
the donald knuth's book also started with algorithms and its efficiencies..
but this book was more illustrative and understandable than cormen's!!!
althou i couldnt understand ny math figures apart from induction :p .
nyways just askin the question is algorithm and study of its efficiencies and runtime via mathematical figures that important???
or can i just jump to programming part???
sandy453
Active Member
Nov 21, 2006
233
12
31
Once you get into real world , you will find yourself applying these algorithms to solve complex business problem.
Big-oh notation is important,so are Algorithm design methods like dynamic programming,greedy method,back tracking etc.
prongs
New Member
4
0
0
hey i have used the following book istin them here.........................
GOTTFRIED
advantages-easy book,good for beginners,quite helpful in basics
disadvantages-doesn't have tough problems,works in TURBO C compiler rather than GCC!!!
LET US C-kanitkar
it is too basic!!,not even one single question OF INTEREST
if u have done c++ BEFORE,DON'T BUY THIS!!!
DENNIS & RITCHIE
:awesome: book
great level questions!!!
Yamaraj
New Member
Aug 12, 2005
405
13
0
Why in the world do people buy Kanitkar's books? :S :mad:
Beginner:
1. C Primer Plus - Stephen Prata
2. A Book on C - Al Kelley, Ira Pohl
3. C Programming: A Modern Approach - K.N. King
4. Programming in C - Stephen Kochan
Intermediate:
1. The C Programming Language - K&R
2. The Standard C Library - P.J. Plauger
3. Expert C Programming - Peter van der Linden
4. C Traps & Pitfalls - Andrew Koenig
5. C: A Reference Manual - Harbison & Steele
6. The C Puzzle Book - Alan Feuer
7. C Programming FAQs - Steve Summit
8. Pointers on C - Kenneth Reek
Advanced:
1. C Interfaces and Implementations - Hanson
2. C Unleashed - Richard Heathfield et al
I can personally vouch for the quality and contents of the books aforementioned, except for King's and Hanson's. And the remaining two are highly recommended by the experts.
Apart from these books, you'll have to through numerous others that use C for algorithms (eg. Sedgewick), data structures, network and systems programming.
Reactions: 1 person
