Budget 41-50k Laptop For VM
santoshwe
Member
35
1
8
Hi Friends
I want to buy a new laptop which can support below
1. hold atleast 32 GB ram (For running VM). Do we have laptops with 4 RAM slots?
2. 4 cores. I perfer to buy AMD models as they seems to be value for money compared to intel and durable as well. It seems the new Ryzen APU models are good. CPU speed is not a criteria. Can go with little less CPU speed as well.
3. Should have the feature to add an extra HDD internally.
Pls suggest a good value for money laptop, preferably AMD model
Thanks
Party Monger
Veteran
Jul 15, 2007
4,548
934
201
Go for an i5 8250u laptop. Dont go for ryzen 5. Its similar price and lesser performance..
Most i5 laptops come with a m.2 slot along with a harddisk. You can simply open it and add an ssd. If you get one with a CD drive, then you can add another via a caddy.
kekerode
Jul 29, 2009
571
7
82
Bangalore
Check out Lenovo P52 model which comes with 128GB memory option. If it's too costly then check older model P50/P51 which has 64GB memory option.
mayank_asthana
New Member
17
3
3
27
How are AMDs for virtualization these days? I have always heard intel chips having better support for virtualization, like supporting hardware passthrough.
navin007
Active Member
126
5
31
33
Mumbai
i was using amd phenom 2 x2 555 it worked nice
too used amd phenom 2 x6 it worked nice
at present using amd fx4300 it is working ok not nice :)
all 3 are desktop
