Need a printer suggestion for light home usage
letmein
Oct 11, 2009
865
1,316
232
Delhi
I need a printer for my parents. The usage will be really, really light. Like a couple of pages a month, mostly tickets.
This HP AIO is going for 3k, decent reviews. The problem is that it's an inkjet, so the cartridges would need to be replaced often.
https://www.amazon.in/HP-DeskJet-Inkjet-Colour-Printer/dp/B013GF4QQE
The cheapest laserjet (that has good reviews on Amazon) is around 8k.
https://www.amazon.in/Brother-HL-L2321D-Single-Function-Monochrome-Printing/dp/B00SHFP99W
I'm really having a hard time justifying this price, considering the low usage. At the same time, on another thread I read that the cost of replacing ink cartridges for an inkjet would be more than the price of a printer over 2-3 years. But then again, I doubt a printer would last for 3 years, so I'm really confused if I should save money and go for the inkjet, or invest money in a laserjet, despite the super low usage.
Any suggestions? Thanks.
technofast
Aug 26, 2011
341
86
67
Chennai
If it is only for printing purpose the below single function printers should suffice. Actually the scanner and copier functions are not needed in a printer now as cam-scanner app takes care of all scanning needs now. Yes, ink cartridges cost more and nothing can be done about that . To prolong the usage of the cartridge just need to print couple of sheets per month. Refill the cartridge for couple of times instead of buying new one which should bring down the cost.
https://www.amazon.in/HP-DeskJet-Single-Function-Printer/dp/B013FV2N5U?tag=googinhydr18418-21&tag=googinkenshoo-21&ascsubtag=b6655db8-d568-450b-b394-2c25701b613d
https://www.amazon.in/Canon-TS307-Function-Wireless-Printer/dp/B07BZFLWS7?tag=googinhydr18418-21&tag=googinkenshoo-21&ascsubtag=b6655db8-d568-450b-b394-2c25701b613d
vaalkai
Active Member
88
35
31
Inkets get clogged if you dont use for long time as far as i know.If its only couple of pages per month, why not simply get it taken from nearby shops? will be cheaper? its not worth the investment.
Reactions: 6pack
Flash!
Vroooomm...
Nov 11, 2011
230
77
42
He mentioned the printer is for the parents. Its easier for them to get the ticket printed in home.
vaalkai
Active Member
88
35
31
Yeah i noticed that, i think printers will be more of a hassle to operate for them. It might be easier to put the file in a pendrive and get the printout from shops. just my 2 cents.
superczar
Veteran
Mar 17, 2005
4,430
528
202
39
A Laser printer without a thought if it's for intermittent usage
I burnt through multiple inkjets till I finally got a Laser which has been running good for over 5 years now
Inkjets dry up if left unused while you can fireup a laser after months of non usage without a glitch
Just pick one that uses commonly used cartridges .. Mine uses the HP 88A for which various clones are available for sub 1K
My usage is a few prints a month and each replacement has run at least 2 years
logistopath
Molar Police
Super Mod
May 25, 2007
3,295
933
202
Erode
Have been using the Ricoh SP111 laser printer for almost a couple of years. Works trouble free. It goes for about 6K rupees on different sites. Keep checking. Official Ricoh toner costs less than 700 rs.
skoka123
May 2, 2008
420
119
132
Not anymore. I have a Brother Inkjet printer that comes with company refillable ink tanks. It has auto clean functionality. I print once every 2 or 3 weeks whereas the printer keeps performing auto cleanup around twice a week. I have this printer for more than 2 years now.
kreacher
Active Member
262
13
31
40
Avoid Inkjets if the printer is going to be used occasionally. I have a HP AIO which costed around 3.5k, cartridges (colour + b&w cost almost 2k). To keep the cartridges from getting clogged, printer has to be used / cleaned every 2-3 which wastes ink.
Reactions: mach9
vivek.krishnan
Veteran
Dec 18, 2009
7,435
1,659
253
Ghatkopar, Mumbai
plus.google.com
If they will use the printer once every 3-4 days, then opt for Epson/HP ink tank printers. I had suggested the same for a collegue of mine, who did not want to pay the premium, and opted for an Inkjet and is now paying the price with refilling cartridges and having printing issues.
If more than that, opt for a laser. If you can, opt for a used 1020/2900B as they have hassle free toners without chips.
blr_p
Veteran
Apr 11, 2007
5,870
1,236
301
The copy function of my all in one laser gets the most use. The scan function is second.
phones need to be set up with good light and are fine for copies of 3D
Image quality is better with an all in one and much easier than using a phone[DOUBLEPOST=1536413641][/DOUBLEPOST]
yeah it uses ink to clear the jets and that ink costs more than champagne.
That is assuming it can clear the jets to begin with.
If colour prints are required regularly then an inkjet might be an option
blr_p
Veteran
Apr 11, 2007
5,870
1,236
301
What i don't like about these models is they are USB only. Not wifi enabled. This means they need to be located either close to and wired to a router or a PC and that PC needs to be on for the printer to work
Wifi enabled is more convenient can be placed anywhere there is a signal. I would not consider a printer that didn't have wifi capability built in. If ever there is a power cut it should on resumption of power, wake up, connect to the network and go back to sleep. There can be some complications involved here depending on how well the software can cope with such a situation. Needs a tech aware person at hand in such a case
If there are any chromebooks in your setup in the future then things become more complicated as you will have to choose printers that are fairly recent and cloud aware. In addition now you will need a working internet connection just to print something which is ridiculous
mach9
Das Layzeemeister
Dec 17, 2007
900
291
153
Anywhere between 0 - 47000 feet
I second this 100% .. the only thing I'm not sure is if this is with all brands or just HP ( I have an HP AIO inkjet with the and issue) but friend with Canon doesn't.
If you don't need colour then a LaserJet might be better.. inkjet will dry up if not used from time to time (HP disclaimer)
skoka123
May 2, 2008
420
119
132
You either have absolutely no clue what you are talking about or you drink real cheap champagne. The printer I am using for the last 2 years is https://www.amazon.in/Brother-DCP-T500W-Wireless-Colour-Printer/dp/B010RGQT8S/ref=sr_1_1?ie=UTF8&qid=1536561941&sr=8-1&keywords=brother+printer+dcpt500w. I am still on the original cartridges that came with the printer. Mind you, this printer comes with 2 bottles of black ink and 1 bottle of cyan, magenta and yellow ink each which I am yet to open.
You should now be able to find much better inkjet printers since my purchase.
blr_p
Veteran
Apr 11, 2007
5,870
1,236
301
Can't find this printer on amazon us & uk. So found the closest equivalent. As long as you use it regularly this means once a week or more inkjets are fine. Go a month or two between prints and the story changes.
rdst_1
Veteran
May 10, 2009
2,512
1,114
253
32
Can most of the printers print on legal size papers or do we need to buy special printers for that.
skoka123
May 2, 2008
420
119
132
Tank system needs to be used once a week as well. There's no getting around clogged jets. They have to be unclogged.
https://www.amazon.com/review/R1TCK3VZS2DYLO/ref=ask_dp_lswr_rp_hza
This problem isn't there with lasers.
That must be an isolated incident. The printer I have was bought in Feb 2016. In 2.5 years not once did I face the problem. I never had the issue with clogging even if I have not printed a single page in 2 months. The key here is the auto clean function. As long as one remembers to keep the printer powered on, one does not have to worry about clogging print nozzles. As I said, even after 2.5 years, I am yet to refill the ink tanks. Also the cost of the ink bottles (prints around 5000 pages) is less than Rs. 500 each.
I used to own a Casio Cartridge based inkjet printer that used to get clogged if I do not print at least once a week. Finally, the print nozzle was so clogged that no amount of cleaning revived the printer. Ink Tank inkjet printers with auto clean completely changes the scenario.
