So we have to keep the printer powered on (in sleep or whatever) 24*7 for the few prints that we may take in a month? sounds extremely wasteful to me.
if its network aware as yours is with wifi then it will be on just asleep and waiting for a job.The key here is the auto clean function. As long as one remembers to keep the printer powered on, one does not have to worry about clogging print nozzles. As I said, even after 2.5 years, I am yet to refill the ink tanks. Also the cost of the ink bottles (prints around 5000 pages) is less than Rs. 500 each.
yes this happened to a canon inkjet i had around 2001I used to own a Casio Cartridge based inkjet printer that used to get clogged if I do not print at least once a week. Finally, the print nozzle was so clogged that no amount of cleaning revived the printer. Ink Tank inkjet printers with auto clean completely changes the scenario.
How does auto clean work. Do you set a schedule
Few people complaining about slow print speed in the amazon reviews. Specs say 12pg/min which shouldn't be a problem.
I'm very happy with my brother laser. Numerous power cuts, its comes back online by itself and then goes to sleep waiting for a job. Wakes up fast prints, then goes to sleep. This is ideal behaviour for a networked device.
Initially I was a bit concerned the power draw when the laser starts might be too high for a lighting circuit. No problems. No flickering lights when it comes on.
Yeah, bought it. Working fine. Sorry, can't really give a detailed review since it's at my parent's place, I'm not using it myself.
Oh ok. How much did you end up paying?
it's functional but its usb only. That means you need to be wired in. Wifi makes life easier but ups the cost.@letmein Did you end up buying it? Mini review please. I'm also in the same boat and debating whether to get a laser MFP or not.
I ended up having an issue with my brother recently. Drum error after just 250 pages. Refused to print anything. The drum's good for 12k pages so surprised. Error msg is slide the green tab. Eh?
googled it then pulled the cartridge out and had to move this green tab across the length of the drum. Took a few tries but apparently toner can get stuck on the drum. Worked after.
And i'm still on the cartridge that came with the printer. Not some generic 3rd party refill.
Have you tried this with other printers ? How well does it workI don't mind it being USB only. Can always connect it to my router to make it wireless.
