Suggest a Telescope ??
Praks
All,
Is there any one on TE who loves watching planets :) ?
Looking for a GOOD telescope for personal use.. here are few requirements.
  • Atleast surface of moon should be visible. More the better :)
  • Comes with a good stand
  • Will be purchasing online for better discounts.
  • Aprox range - 3000 to 8000 Rs (max)
Recently show a deal on Groupon, Not sure about company etc..
Please suggest names of model number & price.
Here are two of the oldest & best places in India to get scopes - with prices in INR :happy:
http://www.galileotelescope.com/products.php?b_id=120
http://www.tejraj.com/products.html
Go ahead & all the best - do not chose "dobsonian" - very heavy; chose newtonian reflector scopes; also check out the "star-tracker system scopes"
There are plenty of sites [to understand "how to choose a telescope"] as well as "astronomy" local groups in India. Which city are you from ? Do not hurry or make haste in your decision.
Cheers
Terry
Negative, except that if you want "good-quality" - then pick it up from the brands available at the above online outlets.
Most of what you get in Malls or other online sites are cheapo chinese stuff.
Its been around 2-3 years since i wanted a binocular. I googled and saw a Celestron model which I like. But the "X x Y" thing confuses me. Also i search for physical stores located around here but didnt find any. Btw the site you posted doesn't have celestron models.
Cheers
Terry
Thank you, Very nice of you. I will check each of them & post feedback.
Major requirement is see surface of moon or near by planet as close as possible. Would you suggest any model directly in my range ?
I repeat again dear @Praks - You need to get familiar with many things pertaining to "scopes" apart from the jargon. Where are you from ?
These days almost every weekend (since the summer skies are the clearest) - trips are organised by these "amateur astronomer groups" - find one in your area and join them for 2-3 outings. They would willingly & joyfully allow you to use their scopes - you will get a hands on experience with a variety of scopes. You will also realise that not every type of scope is easy to use - especially when you have to locate specific stellar objects (using a sky map/android app) etc. Some even carry their laptops with them so that their scope tracking is controlled very accurately.
And yes almost all of these scopes will show you the craters of the moon with remarkable clarity :)
Got this. So what is the difference between them? :S
www.ebay.in/sch/Binoculars-/83880/i.html?_sop=2
Frankly speaking - I hesitate to buy from ebay. Just in case they are not genuine then it's a waste of one's money. The quality of optics that are used in fakes is terrible. This problem gets severe with telescopes.
You could try out this - compare the price of the model you wish to pick up from ebay with the prices listed on the Brands website.[DOUBLEPOST=1368180959][/DOUBLEPOST]Check these 2 videos - Guides to choosing & understanding about telescopes
and why an Equatorial Mount is the best for urban skies
There are lots more videos on youtube. You may also find specific models and their capabilities.
@terence_fdes
Dear Sir, I read several articles on how to choose & all - like http://www.galileotelescope.com/howtochoosetelescope.php
Understood 1 thing - larger a telescope's aperture (i.e., the fatter it is), the more you will see.
Based on your links here are few shortlisted. (price wise)
Celestron
SPACE LAUNCHER 38 #09101 - Rs 710
SPACE LAUNCHER 76 DOB #09203 - Rs 3466
SPACE LAUNCHER 50 #09102 - Rs 4000
FIRSTSCOPE TELESCOPE #21024 for Rs 4573
SPACE LAUNCHER 60 #09103 - Rs 5777
Galileo Skyview I - Astro Terrestrial Telescope - 3000
Galileo Skyview - Astro Terrestrial - 3330
Galileo Sky 767AZ Dia=76mm 233x Reflector Telescop - Rs 5700
I prefer to take from flipkart or ebay (good seller only) so I can get some discount.
Most other stuff is gone above my head hence will depend on you. Please also check this & suggest
http://www.ebay.in/sch/Telescope-/28179/i.html?_sop=2
OT: Anyplace in Delhi/NCR who can repair Binoculars. I need my Binocular serviced for removal of mold/fungus from inside.
@terence_fdes
Celestron
@tterence_fdes
Can you please help & guide.
Dear @Praks, tell me which city/town are you from.
If possible, I will try to locate a local amateur astronomy group. I still insist that you get an oppurtunity to go out and actually check as many varieties of scopes that is possible before you finalise. Altazimuth vs equatorial mount; refracting or reflecting etc.
Astronomy (amateur) can be both exciting as well as frustrating.
The latter can happen when one has picked up the wrong scope and realises that, "I am not getting what I dreamt about". After having glimpsed at the craters of the moon, what next ? The planets - Jupiter's moons; Saturns rings - how easy/hard is it to locate and "track" them [on some scopes - the moment you finally track saturns rings and wish to show it to others - it has vanished (from your point of view); so back again to tracking it - EQ mount scopes are the better than Altazimuth ones for 'extreme far objects'. Things get more complicated when one wants to locate other constellations; nebulae; clusters.
A wrongly chosen scope will soon be relegated to the corner of your home & forgotten.
@terence_fdes, nice post how about a guide, I was following this thread with interest and even I had that question of what next after looking at the moon
You have posed the most fundamental question. Trust me, it's very difficult for me to answer. And the factor's are too many - right from "budget" to the optical capabilities/limitations of the scope that you buy; urban skies and the pollution (which makes most viewing impossible). If however, you do have a vehicle and frequently make trips outside the city - then invest in the best scope that you can afford and discover first-hand what lies in the skies. Trust me - the very first view even of the Moons Craters live is a huge WOW.
Years ago (more than 35 :bored: ), I had used a Celestron that was gifted to me (I do not remember the model number). Star charts were very limited then (I used a simple rotational disc sky map by Nehru Planetarium, Mumbai) to just identifying our sky as seen across the Mumbai Horizon, thus I got familiar with the planets, zodiacal constellations, alpha centauri, the pole star, ursa minor & major & the milky way. And how as the seasons changed and the earths rotational movement around the sun so did the views. Mumbai was not so polluted then. I used to yearn for the nights when there was a total "black-out" across the city due to some major power tripping .... because suddenly you could see a 100 times more stars across the blackened sky. I made a few trips on the outskirts of Mumbai towards rural countryside - and the experience was unforgettable. One can even spot satellites, meteors, comets and "shooting stars" :eek: with the naked eye .... so through a telescope it was more fascinating. I used to teach, train and explain all these marvels to as many folks as I could - and especially children. Apart from viewing these celestial marvels - we also need to think "what lies beyond-the-beyond" and is the Earth the most unique planet in the cosmos ? Then there were times, I used to read and study observations made from professional observatories around the world - terrestrial & space based. Somehow, I realised that I had by then outlived the capabilities of my Celestron and it was time for me to pass it on to another person/generation.
Of course, I must mention, that even for terrestrial purposes (viewing anything across one's line of sight during the day was amazing ...... you can peek through people's lives - 'bedrooms' miles away :p ).
Today, I feel the urge again to start all over and get my own telescope. The tools that are available today are mind-boggling - android apps to track skies/stars/planets/constellations. GPS tracking. Computerised tracking. Just feed in the co-ordinates and the scope will automatically track itself. My limitations are that I live in Mumbai (which has gotten more polluted), no balcony or even a niche through my windows wherein I can squeeze the scope (all windows are grilled):drowning:... So I would have to tug my scope each time onto the terrace & hope for the best. I am also living in a 3 storied building (not in some mega tower 30-50 stories high), so all the neighborhood lights will interfere. Still, I am keeping my options open and want to share this with my daughter.
The "Amateur Astronomer Groups" that exist in so many cities and towns across India are truly fascinating - find one in your own area and expand the scope of your knowledge & experience. Observing & studying the skies as a team/in a group makes it all the more exciting and speeds up the process.
To conclude - for any beginner, your first scope has to be a Refractor - so that you can also use it for day-time terrestrial viewing (reflector & other scopes will give you an upside-down view).
This is what I have found to be the best (and also price wise at snapdeal)
http://www.snapdeal.com/product/celestron-powerseeker-70eq-telescope/1178661/?pos=0;0;429 - EQ - equatorial mount ~ Rs 8999 (with an extra 2% discount)
and the same
http://www.snapdeal.com/product/celestron-powerseeker-70az-telescope/1178675 - Altazimuth mount ~ Rs 5199 (with an extra 2% discount)
Further details about the scope - http://www.telescopes.com/telescopes/refracting-telescopes/celestronpowerseeker70eqtelescope.cfm | http://www.opticsplanet.com/celestron-firstscope-70-eq-refractor-telescope.html | https://www.astronomics.com/celestron-powerseeker-70-eq-2-75-inch-refractor-telescope_p16516.aspx |
Customer Reviews - http://www.amazon.com/Celestron-210...iewpoints=1&sortBy=bySubmissionDateDescending
and lastly
Equatorials vs Altazimuths - http://www.astronomytoday.com/astronomy/tbfaq_7.html | http://www.marcthescopeguy.com/altazvseq.html | http://www.howstuffworks.com/telescope5.htm
I repeat do you own homework & I will try my best to answer (if possible).
Ciao
Terry
EDIT - 20130611
Found a better option for the first-timer
Have a look at this one - Celestron AstroMaster 70AZ Telescope ~ 7949/- This is a more rugged alternative than the "powerseeker-70az" -which has a lot of plastic parts, including the finder scope and the 3X barlow. The astromaster comes with better eyepieces and includes a sturdier alt-az mount with a 'pan-tilt' handle - this ensures a smoother and more accurate tracking (this is absent in the powerseeker & skywatcher model too - where tracking is done by holding onto the main barrel). It's slightly more expensive but worth it.
http://www.celestron.com/astronomy/celestron-astromaster-70az.html
customer reviews on amazon
