Are there any good 5inch android phones available in India? Similar to pixel 4a. 6inch phones are little big for my taste
You mean, something in that form factor, but with newer hardware ?
I am dont think their is anything like that anymore, may be check balmuda phone -
iphone 13 mini was the last mini
If you find anything newer, i would be interested as well.
Finding compact smartphones from reputable brands has become increasingly challenging, as the market trend leans towards larger displays. The Google Pixel 4a, with its 5.8-inch screen, was one of the last great small phones from a trusted brand,so if you’re set on something smaller, you might need to look at older models or consider some compromises in performance or software support.
Yes form factor. The above phne is form japan. Something like zen phone . But they are not available in India
Forget 5 inch, there is not even any 6 inch available here. Foldables are an option if they are up your alley.
Once opened they too are long. Foldable are expensive aswell.
Then importing from abroad is the only option. Unihertz is popular -
Hmm, thanks. Looks like ppl who want smaller form factor phones are minority. Unless that improves we won’t have options
I think there are some on cashify. If you want iPhone then there are tons of options!
iPhone no longer have mini. Not sure which iphone you are talking about?
S24 is the smallest you get these days and it’s pretty small at least compared to what the specs might make you think. Try it out at a shop
Samsung Z Flip if you do not mind a clamshell design.
here have a look
A LOUD minority if you ask me
Phone size phone has its fans
Does not matter if loud, but still minority. So no use:)
Are you any closer now after starting this discussion?
Unfortunately no!!
S23, S24 and Moto edge 50 neo
S23 is noticeably smaller than edge 50 neo. Have both.
Those are all over 6 inch.
S23 is 6.1"
