-Bought on 06-04-2025, invoice attached down in the images
-Condition: Good as new, just 4 few months old, used just a few times.
-Bill and original box both available
-Expected price: 7,999₹
Logitech G502 Hero High Performance Gaming Mouse
-Bought on 26-04-2025, invoice attached down in the images
-Condition: Brand New/RMA’ed Unit, Never Opened/never used.
I don’t break them, these brands have built these mice in a way that you will surely have some problems with them. That is y I run mouse repair service.
Hey @HonestLiar Is this even correct?
your pricing is 7999? when you have attached a bill for 6390? and its also available online for approx. that same amount?
I have installed ginfull V5s hall effect sticks in that PS5 controller. It’s not a normal PS5 controller with stock sticks. After hall effect sticks are installed stick drift is a thing of the past.
I know the controller is still under warranty and could be replaced with a brand-new one if I experienced stick drift. But I went ahead and installed Hall Effect sticks anyway because I’m well aware of how unreliable the stock ALPS sticks are. They’re prone to drift, have a high error rate, and aren’t particularly accurate. In contrast, Hall Effect sticks are not only drift-proof but also offer improved accuracy and significantly lower error rates compared to those stock ALPS sticks.
To give you an idea of how bad the stock ones are: a friend of mine bought a brand-new PS5 controller just a month ago, and he’s already dealing with stick drift. Those factory-installed sticks are absolute garbage.
