Using Carrier 1TON Inverter AC for quite a few years like 6+ years, it stopped working properly now last year alone two times gas change, full gas leak test, spent 10k+ no use, too much noise, reduced fan speed and no cooling
Please suggest good AC with 1.5 or 2 Ton, in Chennai at summer times it goes 45+ degrees, the technicians told me 10x10 room I should have installed 1.5Ton due to open terrace above, so this time I will go for 1.5T or 2T. Also the coolant was mix of two coolants don’t remember the variant it was expensive, which is ideal coolant ? BTW I want to go for OG or Carrier or Panasonic but you guys can suggest other brands as well
AC is used all days including winter, few hours day time, all night as well
