Please rate my PC build and feel free to advice me.
Processor: AMD Ryzen 7 PRO 4750G rs.29232
Motherboard: AsRock B550M Steel Legend rs.12470
PSU: Antec VP 700P Plus 700W rs.4450
RAM: TEAMGROUP T-FORCE 3600MHz 16x2 32GB rs.11391
Cabinet: Antec NX230 rs.3000
Total: rs.60540
I already possess
M.2 NVMe 250GB SSD
and
2.5" 1TB HDD
I will be buying a AIO Liquid Cooling 360mm in future and also extra storage too.
Eventually I will save up some money and buy a good high end Graphic Card.
Please suggest me if this is good or am I missing something or anything in general is much appreciated.
A 3300x along with a dedicated GPU (1650/1660) is a much cheaper and vfm option for now. You could upgrade the CPU later.
The Ryzen 4750G hasn’t been launched for retail market in India yet. (No retail in US also, only OEM). The ones listed on few indian websites are grey market pieces without retail packaging (no box, no OE cooler). No official warranty also. Hence you might have to wait a bit if you’re keen on 4750G in particular.
What is your existing hardware configuration (component name - component brand and model)
Storage - 250GB NVMe SSD and 2.5" 1td hdd
Which hardware component are you looking to buy (component name). If you have already decided on a configuration then please mention the (component brand and model) as well, this will help us in fine tuning your requirement.
(please mention the rest in above format)
Is this going to be your final configuration or you would be adding/upgrading a component in near future. If yes then please mention when and which component
Yes, will upgrade the followings:
360mm AIO Liquid Cooling
Some extras storage
High end GPU
Where will you buy this hardware?
Online
Would you consider buying a second hand hardware from the TE market
Yes
What is your intended use for this PC/hardware?
Game dev (unity, unreal engine) - basics, for learning purpose
Rendering (blender) - just for learning purpose, not very serious
Gaming
Browsing
Desktop Processing
Download rig, 24x7 operation
Watching HD movies
Do you have any brand preference or dislike? Please name them and the reason for your preference/dislike.
No ASUS products pls, we don’t get along well.
If you will be playing games then which type of games will you be playing?
Modern AAA title games with moderate graphic settings
What is your preferred monitor resolution for gaming and normal usage
Gaming - 1280x720
Desktop - 1440x900
Should be fine but I’m flexible
Are you looking to overclock?
Yes, maybe, not sure
Which operating system do you intend to use with this configuration?
Windows 10 64 bit
From where you’re getting 4750G? I don’t think it’s available anywhere in Indian retail market. Probably it never will.
For gaming you would need dGPU, you can’t play AAA titles with iGPU. Go for atleast 1650S.
I assume you intend to go for 3070 or higher in the future, so the reason for 700w I guess. Go for better quality PSU than VP, something line Earthwatts Gold Pro.
It’s a balanced build which you can fit in your budget, i5 10400F + 1650S.
If the high end purchase is in the very near future, then get used GT710 or something for now and go with 5600X or 3700X.
If you really want octa core with iGPU, then i7 10700 is the one.
It will better if you go with 3600 used for 13-14k or 3300x 9-11k
Get a basic card for now`, later as u said upgrade.
The pricing of 4750G is insane now…
My idea was like to get a good core count cpu like 8 cores 16 threads as it will help me in running game engine softwares. Later I got to know about this APU, so this let’s me both game dev and lite gaming. That was my impression and main reason to opt this apu. Ik I can get a low end or used dedicated GPU card, but I don’t want to waste money on that as I will save up and upgrade for high end one.
You can also undercut on ram. I think 16gb is more than fine if you are only starting game dev.
As others have suggested you can go for other cpu like 3600 rather than oem option.
You can use this savings to get a good 4gb gpu for now and then upgrade later.
Stay away form gigabyte boards if you plan for argb/rgb thing as its too buggy. Asus or Msi anyday though msi ass sucks in India else Asrock is good too.
