In my new rental there is this Faber gas stove that doesn’t heat the center of pans/tawas, and rotis come out very weird, I would like to get a conventional burner on this but in my research there doesn’t seem to be a way other than buy your own stove. We already have a stove but would be better to convert this one as it’s one of those flat ones that are integrated into the counter (see last image). I think this style is called “Italian burner” but not sure.
Usually one of the burners is of triple-ring kind, which works well with tawas. The pic you shared has one too.
Check with Faber if they can sell you a spare triple-ring italian burner and valve.
