Anyone upgrading from AirPods Pro 2 to Pro 3? Is it worth upgrading?
I bought mine in Feb 2025 with AppleCare+.
I planned to upgrade when the new ones would release but it seems it’s an incremental upgrade at best.
Had purchased around the same time.
For a generational upgrade, it is quite significant, audio profile aside.
As a new purchase, might make sense to spend extra. Otherwise, makes sense to wait for a price drop.
My main issue is the fit with my left ear. Fits like a glove on the right side but the left falls off every day.
I found a deal to get the new ones for ₹21,000 however I have decided against it for now.
They are still using the H2, BT5.3, etc.
It doesn’t feel like a generational leap considering the use of the same chip.
I will upgrade to the Pros 4 when they come out in September 2028.
