i need to buy a monitor ((22" or 24"),TN or IPS)
basically i will be using this monitor for gaming,graphics designing(PS etc) n 3d modelling(3dsmax etc),Writing game code(programming), and for movies etc as well…
budget → ~13k or less …
BenQ G2420HD will cost around 11k.
or LED based LCDs shall come down to your budget in a few months if you can wait.
none the less, the above monitor wont disappoint you.
any major difference b/w LED and LCD :huh:
and how much PQ difference will be there b/w BenQ G2420HD and the DELL U2311H ?
led is better than lcd in colors n power consumption
however i suppose dell gt2410 is best option than Benq green series. benq is coming with new range also dont know much about them.
then u have the elusive Samsung XL2370 for which i am waiting too but havent seen anywhere. Press release said launched in India in Sep 09 but contacted all places with zero result
so my suggestion is hold on …
i m waiting for a good monitor
