Battery for Acer 5738G
Th battery of my laptop, Acer 5738G, is almost dead. It holds a charge of max 15-20 minutes even on full battery. Clearly, the battery is nearing it’s end very soon.
I wanna purchase a new one. I don’t wish to spend too much as the laptop is almost 2-2.5 years old and I may be purchasing a new one soon (not very soon though).
I just removed the battery and the model number is AS07A31.
Can anyone suggest some good buys for the same? Will other battery models work or will I have to stick with the same battery model? And can I use 12 cell batteries instead of 6 cell?
Thanks.
Regards,
Abhishek Sharma
http://www.ebay.in/dsc/Laptop-Accessories-/31530/i.html?LH_TitleDesc=1&_from=R40&_nkw=5738g+battery+-charger&_odkw=5738g+battery+-chrager&_osacat=31530
You will have to stick with the same battery model unfortunately. A 6-cell baterry for your laptop would cost around 1800-2200 bucks which comes with 6 months of local warranty.
Are the ones with the ‘Original’ mark on the thumbnails really the original ones? :slight_smile:
I do not know what they mean by ‘Original’ ,but it seems that they have a warranty period of about 1 year versus the 6 months.
Hmm okay. I’ll see what I can do. I’ll probably just purchase a compatible battery for around Rs. 1200 to suit my needs.
Thanks for the help! :slight_smile:
