Beginner Level Wireless Lapel Mics for Content Production
I am looking to invest in wireless mics (for 2 people) at a budget of around ₹4k. They should be compatible with mobile devices (both Android and iOS).
I am looking for recommendations from folks who are a bit familiar with audio hardware. To be used in an indoor environment so long-range functionality is not necessary.
You can get the Boya BY-V2
Boya is quite good as a budget mic. The wired lapel mics by Boya were used by almost all Youtubers.
Since Apple mostly uses lightning port (before their recent switch to Type C), I have not really seen wireless Mic receiver, which can support both iOS and Type C in one product. The jack will the different.
If you are going to use with Samsung, read the comments and make sure that the type C version works with Samsung or not. Samsung had some different implementation of the Type C input/output port, due to which the generic Type C earphones did not work with Samsung phones. read the comments on Amazon and see YT reviews if you want to use it with Samsung.
**Note - **I have provided links to 2 mic combo packs. There are 1 mic options available from Boya (You can take 1 lightning port version and one Type C version)
Lightning port version :
https://www.amazon.in/Boya-Omnidirectional-Microphone-Transmitters-Rechargeable/dp/B0BLNV2LCD
Type C version :
https://www.amazon.in/Boya-Omnidirectional-Microphone-Transmitters-Rechargeable/dp/B0BLNT4QQ1
Editing : Way too many options and choices with lot of chinese clones of same models. For budget wireless microphone I only like Hollyland series of microphones. Audio quality and build quality seems to be a hit or miss for others.
Would recommend hollyland models for decent quality for price.
Hollyland Lark M1, M2, C1
I got the Boya V10 (Type C - 1 Microphone Set) and am quite happy with the sound it records.
I didn’t go for the 2 mic set outright as I was cautious and unsure about the brand; felt I should buy one and give it a go before investing more currency.
Thanks for the recommendations guys.
