Best Graphics Card for old rig
Which is the best graphic card i can buy for the rig having the following config.
Amd Athlon 3800 x2
Gigabyte GA K8N Pro Sli
512*2 DDR 400 ram
Seventeam 420bkp PSU
This comp will be used for casual gaming,movies etc…Currently using 6600 Pci-e
Well u have the best VFM gfx card for ur system…getting anything else won’t effect much…stick to the 6600
If you must get a 9500Gt
Ooops Posted in the wrong section…mods please move it to correct section…
@ronnie_gogs:Need better than this coz thiz one cannot play some games
@Audi0slave:It Wont bottleneck ?
Get Xpert Vision HD 3650 512MB at 3.2k only
^^ In the reviews it says it has PCI-e V 2.0 and i guess my mobo has V 1.1 will it work ?
Dont’t wory
All 2.0 Card are backward compatible to 1.1 its just that it wont be able to use all 2.0 features. There will not be any noticable differrence in casual gaming.
I have a budget of around 4k…which one should i buy ?
I am also concerned about what ronnie_gogs said in the 2nd post
a 3450 or a 8600gt…:slight_smile: :grinning_face_with_smiling_eyes:
Xpertvision 9600GT will fulfil all ur needs for 5.5K…its the best…ur proccy might b bottlenecked a bit…but still it 'll outperform all the cards mentioned above by good margin(atleast 20-30%)..its a onetime investment i say u go for it!!!
Wont have any stability problems ??
Other techies also pour in your suggestions please
How will be an EVGA 8800GTX fitted with an Arctic Cooling Accelero Xtreme 8800 ???
Getting it for 6k and is used for 3-4months
Also i have seventeam 420bkp will there be any problem ?
fast guys i dont want to lose this card if its good for my rig.
9600gt will serve u further
9600GT as i said is enough for u…OR get 8800GTS from market section some1 is selling it around for 5K…
Basically you will not notice a huge diff between the 9600GT and the 8800 due to your other components. Also which monitor do you have ?
Right now i am on a Samsung 15" LCD…Will get new 19" LCD next month
Get the 9600GT, as you will not be gaming at insane resolution.
^^^Which brand should i go for ?
I am getting a used Asus EN9600GT 512MB for 3k is it a good deal ??
super deal… But I am talking it terms of Rupees
Ofcourse…I am getting the card for 275 UAE Dirhams which is around INR 3.3k :face_with_tongue:
Can u get one for me ??? :grinning_face_with_smiling_eyes:
