Best SAMSUNG mobile - general purpose
Someone I know is looking for a SAMSUNG mobile.
For a non-gamer , non-techie.
Budget is less than 20K
F14 at around 9k in sale is the best. there is no samsung phone that offers 2x for 20k.
And is the S21 FE 5G worth 29K, if I can persuade the person to up the budget.
M14 and M15 are both below 15K. M14 has Exynos 1330 while M15 has MTK Dimensity 6100+; don’t know which one is better. I’ve used an Exynos 9611 phone in the past and it used to get pretty hot. I’ve heard that Samsung phones below 20K or maybe only the M-series phones, have a motherboard issue after about a year, so please do your research before buying.
No the s21 FE is pretty old now and is not at all worth 30k, the a55 was selling around that price during the sale and will probably be cheaper or the same in the october sale so you can wait for that but do not buy the s21 fe new, you can buy it used for around 20k but not new.
M35 is a new launch, 4 years of promised updates, 16k after discounts.
go with M15 has MTK Dimensity 6100+ (min. 6 or 8gb RAM),
Buy OnePlus ditch Samsung
M15 is ok, above that M35 should also be decent (considering that Exynos was used in A series earlier & was ok in terms of heating & battery life). Avoid S21FE (both snapdragon & exynos), can ignore other Samsung phones as well.
thanks guys. the person is leaning towards M35 or A34.
M34 is also a good phone. Just bought it for my father for 14k
M35 looks like a perfect fit for your budget.
Between the M35 and A34 I would suggest to go for the M35 it has bigger battery, better design, same cameras, better performance and will probably receive updates for a longer time.
I would recommend the m35 over m34, I bought m34 recently at 12k a week before the primary day sale and i am mostly satisfied with it other than some minor ui lags.
If you are able to grab m34 for a similar price then go for it but it doesn’t make much sense to buy it at the current price because by paying 2k more you will get 1 year of extra os updates, stereo speakers, better processor and a punch-hole display.
Thanks brought this for my mom upgraded with exchange from a3 years old m32 was 12.5k after exchange. Pretty good deal, she’s loving the bigger brighter screen and nicer louder speakers. Camera seems to be good too.
