Best Thermal paste? For both GPU and CPU.
Hello,
Best thermal paste for both GPU and CPU?
I am going with this:
Gelid Solutions GC-Extreme 3.5g with Tooling - Thermal Conductive Paste for Heatsink | um Thermal Conductivity | Easy Application | Not Corrosive.
https://amzn.eu/d/21LQPVN
Is it good enough but should within 500rs. That’s why.
Thermal grizzly is highly recommended. It’s the best thermal compound out there.Well worth the slight premium that one is paying.
Only con is that it’s a tiny package of 1 Gram and it’s only suitable for 3 application at max.
Every person you ask will have a different opinion.
Some would say this is just fine other would go with Arctic/Noctua/Thermal Grizzly etc.
If you care about 1-2°C difference then watch hours of youtube videos else just buy any of those.
Actually yes. I am a fan of ARCTIC but thermal grizzly is slightly better. But it’s way much more expensive than ARCTIC.
He wanted the best so i posted about Thermal Grizzly. Otherwise for all my CPU, GPU, and multiple CONSOLES i use ARCTIC MX4.
Well if you want the best buy kingpin Kpx paste
Holy crap. 3.7k for thermal paste.
No thanks. :flushed_face:
https://amzn.eu/d/5N2jNH6
LMAO that’s some stupid sellers. Shit’s expensive for sure and for a reason since it’s used in OC competitions and LN2 cooling…
https://mdcomputers.in/kingpin-kpx-1.5g.html
1.5g for around 800 INR but OOS.
Can vouch for this. For my 3080 FE, it was the best among mx4, Arctic silver ceramique 2.
Unless you’re looking to min-max get any decent decent brand like AS or TG, most quantity or lowest price relatively.
Mx4 and Mx5 are good for both and don’t put hole in pocket also.
gc-extreme gives excellent performance for the price. 3.5g 500₹
Kryonaut is expensive and beats the former by 1-2°C difference. 1.5 for 600₹
I used gelid extreme on my Rog g531 laptop
works really well, brought down idle temps by atleast -8-10°C
kronaut has pump out effect
Deal of the day @ Rs.399 4gms, Arctic MX4
Deal of the day: ARCTIC MX-4 - Thermal Compound Paste - Carbon Based High Performance - Heatsink Paste - Thermal Compound CPU for All Coolers - ACTCP00002B https://amzn.eu/d/fxvRxzf
Pain
You can cancel it and reorder from my above link.
If you have a way to travel in the past and do that let me know as well. I would also like to have some free money this way. :tearsofjoy:
That order was from last year
Didn’t notice the year sorry. I am still in 2021 maybe.
I always tell my family that I am still 42 years old while I am born in 1979.
If you don’t care about wanting the ultimate lowest temps, go with MX4. I’ve been using it since a decade.
If you want a better option, go with Thermal Grizzly Kryonaut.
No am already using MX4 so its already under good deal so I will go with it. That Thermal Grizzly Kryonaut is costly IMO.
