Cable - Mini DP -> DP || DP -> DP || Mini DP -> VGA
Interested in buying these cabes : -
Cable - Mini DP → DP || DP → DP || MiniDP → VGA || Display Port male to HDMI female
DP = Display Port
Please mention the prices , length and brand in PM
bump…
bbump…
bump…
bump…
bump…
bump…
still looking???
yes…
which one u want???
— Updated Post - Automerged —
mini dp to dp…no…dp to dp …ok…mini dp to vga…ok…dp male to hdmi female…ok
mini dp to vga OR mini dp to DP convertor+DP-DP cable
i am looking at ur site..add it to your signature
mods won’t allow tat in signature:(
mini dp to vga is available
dp to dp cable is available…
mini dp to vga 900 bucks
dp to dp cable 1200
can you send me images/make/model or company of the minidp to vga cable . some makes of the cable are reported not to work with my laptop
thr is no particular make… as we import them ourselves… if it does not work… u can give it back to me.. no problem…
issues with the convertor are mostly chipset related… n not pertaining to a particular laptop… if a good chipset in thr… it gonna work on any dp output…
wat happen???
i bought a direct minidp to dp cable …also do you have HDMI to DP (this has better chances of working than miniDP to dvi/vga)
its dp to hdmi female convertor…again i don’t have direct cable
