Need one of those modem cum routers for BSNL broadband. The use is a few hours a day, at 10ft from the modem.
Budget? Cheaper the better. Ideally sub 1k, but will consider options that are higher too.
Sub 1k you won’t find any modem plus wifi, you will get modem OR just wifi.
There is a Tp link one for around 1500-1600,that works very well, 3 years warranty and is the cheapest.
@Party Monger - I agree with @prateekS. The cheapest Modem+Router+WiFi would be around 1500-1600. For example in Nehru Place, Delhi the following options are available:
IBALL BATON M+R N 150 for ~Rs. 1600
D-LINK MODEM+ROUTER N150 for ~Rs. 1700
NETGEAR M+R+N150 DGN1000 ~Rs. 1950
TP LINK M+R N150 (8951) ~Rs. 1600
I got the tplink single lan port wifi adsl router from flipkart for 1600.
Its working great
Just FYI, the prices on flipkart are like pendulums. the one I wanted to but(4 lan ports) was 1480 then it went to straight 1900. In a few minutes. Be mindful of the stock at the price level.
I too have seen the samsung galaxy y range from 4.8 k to 7.8 k . Don’t know why it happens .
