'check drive for errors' Report
Whenever I opt for ’ Check drive for errors’ there is a report, but it goes off so soon that it is impossible to go through it. Where, in windows 7, it is stored so that one may have a look at it ? Thanks
i’m having the same problem
any suggestions
check in event viewer. will be in Application or System part.
My o/s is windows 7.In order to see the report, you have to work as suggested below:-
start>type in the searchbox ’ eventvwr.msc’ (without commas)>event viewer local>windows logs> application>wininit
This is ’ check drive fir error report’.
Thanks, 6pack.
