Hi
I need to buy Cold water dispenser or a Refrigerator for my staff of 8. Mainly cold water is needed. What works out better in long run, a Refrigerator which has life of more than 12 years or these water dispenser which are quite popular.
A dispenser is costing around 7k to 8.5k wherè as a Refrigerator would be 10k to 12k with star rating varying from 1 to 4.
Its confusing as the electricity cost maybe high in refrigerator. Mainly would be using for 10 to 12 hrs per day.
Anybody has first hand experience of water dispenser and how are they in long run.
These days we have water dispensers with refrigerator at the bottom in the range of ~9k. Buy one preferably of blue star.
Yup, have seen those but firstly they dont cool like refrigerator and have read lot of negative reviews as well about it.
We have both - but the water dispenser is surely useful.
Water dispenser would be better of the two since it can directly fit 20 litre barrels and refrigerator will be less effective with frequent opening of doors (unless dispenser is built in) and one cant fit 20 litre barrels to it IMO, so one will have to fill water too frequently in it. Will surely consume more electricity than dispenser. So unless there is use of all the space in refrigerator its not worthwhile.
Best suggestion is, avoid refrigerated water. Its very bad for health. Either use cool water from clay pot (mataka) or room temperature water.
+1
Get a water dispenser with a refrigerator below instead of just a refrigerator.
