Hi,
I want to know which computer cabinet/chassis can fit Zotac GTX 260² Core 216 in it easily without blocking any airflow.
Weight & Dimensions of Card:
<> **Weight 2 lbs **
<> Dimensions 13.26“ X 10.23“ X 2.67“
My Budget For Cabinet is Rs. 1,500.
Earlier I was planning to buy Cooler Master Elite 332 for Rs 1,500
Plz Reply Soon
it will fit fine in elite.
in elite 332?
because in its online manual its written that it will support graphic cards of max width: 252.15 mm while zotac is 336.80 mm wide.
I have had 260 in elite…
U can even fit 13" long card in elite, no problem.
9800GTX and GTX 260 have same length, see space -
does all elites have same width for cards coz I’m going to buy elite 332.
I hope u say yes
Yes all elites have same dimensions.
Thanks u made my day cheers
