I am looking for a cooler for my HD 4850 as summer is approaching. I was thinking of the Arctic Cooling Accelero S1 Rev2. along with the Turbo module for the same.
Just want to know if there are better options and also where can I get hold of the Accelero S1 Rev 2. or other coolers and their approx prices?
One option may be for you to check out RivaTuner. I’m not sure if it is compatible with the 4800 series of gpu’s, but I use it for my 3870’s and the temps stay way down when i manually set the fans up to 80-100% speed. Check it out. It may save you some cash. Good luck to you.
Get the Accelero but ditch the turbo module. Get a cheaper 120mm fan like some Amigo, snip the LED wires (looks gay with those ) and attach the fan using the zip-ties. Way better than fixing the Turbo module.
Oh and do ensure that u get the sinks for the VRM modules meant for the HD4850.
Dont think there’s another cooler any cheaper than this.
PS: Long time man.
Lol, Sidhu, not everyone changes cards like clothes.
Using the stock cooler with Rockfella’s trick, dont assume u can take the clocks higher which could be quite possible using the AC S1.
The first batches of the S1 Rev.2 (Like mine / Gannu ) did not have heatsinks for the VRM area of the 4850. It was included in the next batch (Like Ethan Hunt ). You just need to ensure that the one you buy isn’t the older one without the heatsink.
@Mohit, do try removing the plastic cover of the card, clean the heatsink and tie a 120 / 92mm fan directly and check results. Then take the jump if necessary.
^^Thanks for the help. I just downloaded Catalyst 9.1 and noticed this “Manual fan control” option in it. Right now using the card with the fan at 55% and temps seem to be fine. But still planning to get the cooler before summer.
He can do that with ATI CCC also but still load temps with fan at 100% reach 90+ degrees as the stock cooler is so poorly designed that it attracts dust and clogs the vents pretty fast.. say 15-20 days or so…
Accelero is no longer available with KMD, from Amarbir its almost 2K without the turbo module. Dont know whether its worthy or not. I got a cheap VGA cooler for Rs. 400 (Second hand though)
Yup, this VGA cooler is avl for around Rs. 500 from dealxtereme, extreme VFM truly!
Trust me Freaks, those additional VRM sinks that AC provides are complete POS. They aren’t properly sized to fit those VRM’s on the 4850. I tried & tried to fit them in every possible way but they wouldn’t balance themselves & would fall off. Finally got rid of those & am running the card without an VRM sinks now. Working fine till now, so hope for the best.
The problem is I don’t exactly know where to get those VRM’s, more so which ones in specific. I have been running the card without them for like 3 months now. The temps never cross 50 degrees, EVER. But since there is no software to monitor VRM temps, I guess that leaves me with no choice but to carry on.
