Works fine to cool my 5700x, the commander core support 6 totals fans and argb devices, with the 5 fans plugged in this was caring for my cooling requirement for itx rig in zeb woodan, Moved back to air cooling and moved cpu to 5600g so this is no longer needed. If you are local to mumbai you can come to my place on a weekend and check this before buying.
I must say once you play around with the argb it comes out to be very pretty.
