Didn’t get your query properly, but a crossover cable is needed when connecting two ethernet devices directly without going thru a hub/switch/ router or a hub/switch to hub/switch. But most devices nowadays auto detect the type of connection and compensate, so there’s no need for a crossover or straight cable.
I want to transfer data from my desktop to laptop and need a really good transfer speed as its a lot of data ~400GB. Ive heard that a cross-over cable helps in that. But dont remember what exactly needs to be done to configure that.
Right after i attach my desktop and laptop with this cable, do i need to do anything else? I dont even see any kind of detection of local area or anything.
Hope this helps
Thanks sumchamp, tried this but didnt really worked.
Meanwhile, searching google, but keep pouring in with suggestions
Gateway and DNS: leave blank - let the internet connection sort out your DNS, and it will be the gateway for this PC, so you don’t need to set a gateway at the network card.
Laptop
IP Address: 192.168.0.2
Mask: 255.255.255.0
Gateway: 192.168.0.1
DNS: The IP address of your ISP’s DNS servers. If you don’t know these, connect to the internet on the Desktop PC and on that PC type the following at a command prompt:
ipconfig /all
This will cause a listing of you IP settings to be shown, including the DNS setting assigned to the internet connection. Use the same DNS IP addresses for the laptop.
