dd-wrt compatible router, with usb for attaching external drive
please suggest dd-wrt or openwrt or tomato firmware compatible wireless router ,
which have usb port/s for attaching external usb disk/s
No other requirements, except reliability . Just dd-wrt and a usb port for a simple NAS like usage.
Budget: flexible, cheaper the better ;).
Thanks
Low:
http://www.amazon.in/Asus-AC51U-Dual-Band-Wireless-Router/dp/B00UJKH0JA/ref=sr_1_1?ie=UTF8&qid=1484370365&sr=8-1&keywords=asus+ac51u
Not sure about WRT for Netgear one so please check..
Mid (single band):
http://www.amazon.in/Asus-RT-N-18U-2-4ghz-Wireless/dp/B00NOWFV32/ref=pd_sim_147_6?_encoding=UTF8&psc=1&refRID=1GG6J3QH1RXXTJDEBY4R
High:
http://www.amazon.in/Asus-AC1900-Dual-Band-Wireless-Gigabit/dp/B00FB45SI4/ref=sr_1_1?ie=UTF8&qid=1484370731&sr=8-1&keywords=asus+ac68u
(I am having this one and in one word it’s AWESOME)
These are great, but I was hoping to get something that was still cheaper :expressionless: .
I am completely ok with routers from not so popular companies, as long as they are listed on dd-wrt site of course.
This one is openwrt compatible. I’m using it as a 4g router.
http://www.gearbest.com/networking-communication/pp_270587.html
http://www.amazon.in/TP-Link-Archer-C50-AC1200-Router/dp/B0168G0KZY/ref=sr_1_4?s=computers&ie=UTF8&qid=1484404606&sr=1-4
I am late.. Initially I had dismissed it without a thought. But after actually seeing it this looks perfect!
Only question is how much wifi range this device has ? Could you please tell about that ?
My house is approx 900 sq ft . Router is placed in the middle of the house.
For streaming in your entire house you will need high power router like RT-N-18U. NEXX WT3020F isn’t just cut out for this job.
Get this: http://www.banggood.com/Xiaomi-Router-Mini-AC-Intelligent-Wifi-Dual-Band-Max-1167Mbps-White-p-964846.html
Then flash padavan or gargoyle firmware.
^ My hero. Ordered!!
Its Also available on ebay.in @ Rs.2000 : Pardon Our Interruption...?
!!CHECK LANGUAGE BEFORE BUYING!!
PS:Already ordered it from ebay.in, THEN checked to see that the language of the UI could be in chinese. HOWEVER since its being sold on ebay india, it IMHO would be in english. ALSO : https://www.aliexpress.com/store/product/Original-Xiaomi-Router-Mi-Wifi-Router-Dual-band-2-4GHz-5GHz-1167Mbps-Support-Wi-Fi-802/1739322_32372291379.html claims that the language can be changed…so lets see.
I’ll update you guys.
So I asked the seller and got a quick reply:
Do let us know if the language can be changed or not after you get the router. I’m also interested in buying this one.
Edit: Thanks to an english version of a chinese version(pandorabox) of openwrt firmware. The router now gives terrific wifi performance. Link: MIUI 14 -Xiaomi Global
Everything in router is chinese, language, home screen, etc. But the language CAN BE CHANGED to English. HOWEVER it’s a bit of a pain + plus openwrt doesn’t give great wifi reception. still trying to scour the forums.
Default xiaomi storage sharing seems ā€˜propretary’ - Use our app to access files. I really doubt the default xiaomi firmware has support for samba shares.
Verdict for Most People : ABORT!
Edit: Seems like a great router working with the pandora firmware (link in the top edit). However its a pain to setup..
Here are instructions to convert interface to english- Unboxing Xiaomi Mi WiFi Mini Router & English Set up Guide Ā«
PS: If you have a static IP then first select the DHCP option, then when in the interface - change DHCP t0 static (it will be in chinese)
Abort? or did you managed to flash the pandorabox from Mi forum?
I managed to flash the pandorabox from the forum. its working goood now.
I guess the final verdict after more testing? :wink: Specially the NAS and streaming usage.
Final Verdict:
**Installation of openwrt **(I recommend getting the optimal version of the pandora-openwrt from the page, in the above posts):
As described above, initial language change is kind of painful.
In addition flashing 'may ’ not be so straightforward. I personally took the long route of flashing multiple firmwares via command line - linky, before reaching my final setup.
But the short method above ā€˜may’ also work. I didn’t know about it earlier , so didn’t try. And don’t know.
NAS/streaming:
100mbs ethernet on this, that’s 11 MegaBytes/sec speed over lan. Which is more than enough for me.
Streaming over LAN via a 10 meter cable is as good as instantaneous on PC. Seeking is also instant.
Range is simply great! for my average size 2.5 bedroom, everything is covered.
streaming over wifi: No problems playing a 2GB file abt 10 meters away from the router on a redmi prime 2.
!!IMP!! wifi streaming speed and range were pretty bad on the official openwrt firmware… download page for the curious : Index of /chaos_calmer/15.05.1/ramips/mt7620/
Does the internet work fine while streaming the large file? On many routers streaming over wifi tends to bog down the whole network.
^looks like it. streaming 2gb file on mobile and youtube on LAN both working saath saath.
what about both over wifi?
