Dead GPU fans (giving away if anyone can fix and use)
Inno3d shroud with broken fans, the fans stopped spinning suddenly while gaming.
I believe the issue is with the GPU fan header rather than fans because the fans failed one after the other (one by spinning to 0, other by spinning to 100 always for 10ish days then 0), although I didn’t get time to get it checked.
Giving it away for free if you can manage shipping cost, maybe useful for some DIY stuff if easily fixed.
Can I have this?
This would be so much useful for those with broken fans, OP is very OP
And what about the gpu, is it working or problematic? And what gpu series/model it is.
Currently reserved for @@hairlessmonkey, then @@Alucard1729 as they were the first ones to dm.
GPU is working completely fine! It’s a RTX 2060 Super
Am interested if the others back away
Can I have the heatsink
I have a Kraken G12 in case anyone wishes to use it with this GPU.
[Like this.](’
https://www.reddit.com/r/NZXT/comments/bxz76n/kraken_g12_working_unmodified_with_rtx_2060/
Packaged and shipped to @@hairlessmonkey
It’s in use on the GPU
Package received. Thanks a lot @@SiniCAT
