Devops roadmap
I recently found a great resource for learning DevOps: the [Roadmap.sh DevOps Guide](’
DevOps Roadmap: Learn to become a DevOps Engineer or SRE
). It’s a visual, interactive guide that helps you learn DevOps step by step, from the basics to more advanced topics.
If you’re new to DevOps or just want to sharpen your skills, this guide is a great resource. Check it out to see where to start and what to focus on next in your learning journey!
Awesome share. Just what i needed. Crystal clear road-map. Jenkins is most used tool in ci/cd imo. Thank you.
well thats too detailed , irl you dont need to know all the things mentioned in and out - it is just focus on one or two tools in details , rest all working knowledge should suffice unless you are applying for an architect role…I would pick K8S & CI/CD tool as core and rest workign knowledge and how they do interact is what is needed at most…
This! It’s easier and faster to pickup tools as we go.
The [beginner’s roadmap](’
) is a better approach IMO (I’ll skip terraform too).
Disclaimer: I’m not a DevOps expert.
